Jeep Axle Width Data.
Greenwithenvy
Chelan, WA.
79' CJ7, 401 AMC, T18, D20, D44, D44.
Default Jeep Axle Spec's
Axle Width Data
Factory tread with is not WMS to WMS. It's center of stock tire on stock wheel to the same on the other side. It depends on offset of wheels and several other factors. Tread width is usually narrower than WMS to WMS because of the off set the center of tire is farther inboard than WMS. Use this chart for comparison.
CJ8s can have both wide and narrow factory axles
The J-10 axle is wider than a NT and narrower than a WT.
'41 to 45 Jeep MB: 48.25"
'46 up CJ2a , CJ3a : 48.25"
'49-65 Jeep Utility Wagon: 57"
'49 Willys Jeepster 2WD 57"
'52 up CJ3b : 48.44"
'52 M-38A 49.19" (Military width)
'54-71 CJ5 48.44" (so called early narrow axle)
'55-75 CJ6 48.44" (so called early narrow axle)
'47-65 Pickup (the classic) frnt-56" rr-63.5"
'63-69 J-200, J-2000 65.5"
'63-69 J-300, J-3800 65.75"
'70- 72, Gladiator J-2000 frnt-63.5" rr-63.81"
'70- 72, Gladiator J-4000 frnt-63.8" rr-64.38"
'73 J-2500 frnt-63.5" rr-63.8"
'73 all other J trucks frnt-63.9" rr-64.4"
'74-75 J-10 frnt-62.9" rr-63.8"
'76-87 J-10 frnt-63.3" rr-63.8"
'74-75 J-20 frnt-62.9" rr-64.4" with disc brakes: frnt-63.0" rr-64.4"
'76-84 J-20 frnt-64.9" rr-65.9"
'63-72 Wagoneer 57"
'73 Wagoneer frnt-57.3" rr-57.5"
'74-75 Wagoneer frnt-59" rr-57.5"
'74-75 Cherokee (full size) frnt-58.8' rr-57.5"
'76-91 Wagoneer, '80+ Cher frnt-59.4" rr-57.8"
'76-79 Cherokee (full size) frnt-59.2" rr-57.8"
'76-78 Cherokee S frnt-59.5" rr-58.5"
'76-80 Cherokee Chief 2 dr. frnt-65.4" rr-62.3"
'81-83 Cherokee Chief 2 dr. frnt-65.3" rr-62.3"
'67-71 Jeepster C-101 50"
'72-73 Commando C-104 frnt-51.5" rr-50"
'72-83 CJ5 , frnt-51.5" rr-50" (so called-
'76-81 CJ7 , CJ8 ('81 only) frnt-51.5" rr-50" narrow axle)
'82-86 CJ7 frnt-55.8" rr-55" (so called- wide axle)
'82-85 Scrambler, CJ8 frnt-55.8" rr-55" wide axle )
'84-87, 93 up Cherokee XJ 58"
'88 up Cherokee XJ 57"
'86-92 Comanche, 57"
'87 up Wrangler, YJ/TJ 58"
'93 up Grand Cherokee, ZJ/WJ 58"
http://jeepTech.com
Axle Width Data
The New Jeep Tech Pages!
All great reference info, appreciate you capturing the Jeep list in one place. That said and not trying to be an a-hole, which do you list here, wms-wms or tread? Just asking because you weren't exactly clear and the CJ widths look less than the wms-wms numbers I've been looking at recently as I plan out a '46 CJ2a resto-mod.
Thanks for clarifying,
Ty
