Jeep Cherokee Shackle Kit
Im Not Spam
News Posting Bot
More fresh parts from the Rough Country stable.
Optimum Articulation
Fine Tune Your Jeep XJ with Rough Country's Shackle Relocation Kit
DYERSBURG, TENNESSEE— Fine-tuning the rear suspension travel of your Jeep XJ has never been easier, thanks to Rough Country's Jeep XJ Shackle Relocation Kit. Featuring a set of frame brackets and shackle brackets, this kit relocates the stock shackle positioning, preventing it from bottoming out against the unibody. Once installed, the shackle is capable of a much greater range of motion, offering increased articulation for off-road use. Whether you run a stock or aftermarket shackle, need to accommodate various sized leaf springs, or want to use in conjunction with a separate lift kit, these shackle brackets offer 5 different mounting points which allow you to select the shackle angle you prefer with the equipment you have. Depending on which mounting point you select, this kit can provide up to 1.5" of lift as well. These powder coated components feature 100% bolt-on installation, making them one of the easiest Shackle Kits to install in the industry, all at an industry leading price of $119.95
Formed in early 1970’s, Rough Country Suspension® Products was a founder of the off-road industry and is one of the fastest growing manufacturers and marketers of lifted suspension packages and off-road accessories for 2wd and 4wd trucks and SUVs. Rough Country Suspension® Products is owned by Heckethorn Products® which boasts a rich history in the automotive aftermarket, including the invention of the first steering stabilizer for military Jeeps in the 1950s. As a complete supplier, Rough Country Suspension Products offers retailers, wholesalers, and consumers an opportunity to purchase easy to install off-road products the market is demanding.
CONTACT:
1400 Morgan Rd.
Dyersburg, TN 38024
800-222-7023
www.roughcountry.com/
Jeep Cherokee Shackle Kit | Digg It | Add to del.icio.us
More...
CONTACT:
1400 Morgan Rd.
Dyersburg, TN 38024
800-222-7023
More...
