    To dismiss this notice
    click the top right X.
Jeep Forward Control Moab Prep
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
This time next week I'll be in Moab, Utah for the Easter Safari. The question is will my Jeep?
I recently replaced the tired front drum brakes on my '64 Jeep FC with a disc brake conversion from R&P Off-Road. It was one of those conversions that practically fell onto the truck! It did require a small bit of grinding, but in less than a day the front end was buttoned up. To say the least I was impressed by the kit. My truck has a closed knuckle Dana 44 , but the kit also works on 1941-76 jeeps with different closed knuckle front axles.
The problems arose next. I went to bleed the brakes and the nearly 50 year old brake bleed on the right rear wheel cylinder was busted off. Then I tried to pull the drum to fix the wheel cylinder, and the hub is pressed on the axle shaft outside the drum, so I need to track down the appropriate hub puller. Then I noticed that brake line is rusted hard and falling apart, so I have to replace that as well. Odd how the upgrades went 100% smooth and the simple maintenance is fighting me every step of the way. There are a few other minor upgrades and repairs that I'd like to do just so I can cruise it safely on the red rocks and I'll be posting those as well. stay tuned
http://pwpinc2.qwestoffice.net/prod_brakes.htm
Jeep Forward Control Moab Prep | Digg It | Add to del.icio.us
More...
