Jeep Gearing
Im Not Spam
News Posting Bot
Jeep Gearing
Lower gearing is a pillar of off-road performance. It allows the engine to turn bigger tires more easily and move your 4x4 over trail obstacles. But adding gearing has often meant expense in axle gears or Transfer Case replacement as well as driveshaft adjustment. With Advance Adapters' new RubiCrawler for Jeeps with the 42RLE Overdrive automatic Transmission , you can now multiply your Jeep's low-range gears after a short day's work of installation. Even better is the fact that no driveshaft modification is needed, as the RubiCrawler literally replaces a big empty space in the tailhousing of the Transmission .
Read More | Digg It | Add to del.icio.us
More...
More...
