Jeep Headers
Jeep Headers
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Jeep Headers
Head on!
Brown Dog Offroad Announces Full-Line of High Performance Engine Brackets for After-Market Headers.
Jeep Wrangler YJ and TJ, Cherokee XJ, and Comanche MJ owners installing high-performance aftermarket headers can now protect their investment by upgrading to high-performance Brown Dog Offroad engine brackets for headers.
Gilbert, Arizona, February 09, 2010 – Thanks to Brown Dog Offroad, Jeep owners installing an aftermarket header can now install high-performance engine brackets and motor mounts that may protect the exhaust header from cracks caused by weak brackets and mounts.
According to exhaust manifold warranty experts, weak engine brackets and mounts, loose or missing exhaust hangars, and improper torque practices during installation are among the leading causes of cracked manifolds.
The new line of stout, yet compact, engine brackets provide plenty of room for aftermarket exhaust headers, yet firmly hold the engine in place, putting less stress on the engine exhaust system and other driveline components. Weak or worn brackets and mounts allow more torsional forces to transfer to the driveline, and ultimately the exhaust manifold,
“All Brown Dog engine brackets are designed to bolt directly to the engine block with no modification required,” explains Tim Shideler, Chief of Engineering, Brown Dog Offroad. “While the brackets can be used with original equipment motor mounts, high performance Brown Dog motor mounts will to a superior job of holding the engine firmly in place.”
Brown Dog double-welded, all-steel upgraded header engine brackets are available for Jeep Wrangler, Cherokee, and Comanche with 2.5L, 4.0L, AMC 258 i6 / 4.2l , and particularly 6-cylinder stroker engines.
“B” model brackets are direct replacements, attaching to the same engine block thread bosses as the original brackets.
“S” model brackets utilize additional engine block thread bosses to further reduce stresses from higher engine torque and off-road activities. “S” models are also used to “save” an engine after original bracket bolts shear or otherwise damage the thread boss.
• B2569-LH, 4-bolt bracket for all 2.5L Wrangler, Cherokee, and Comanche.
• B2572-LHX, 3-bolt bracket for all 4.0L Cherokee XJ.
• S2572-LHX, 7-bolt bracket for all 4.0L Cherokee XJ.
• B2572-LHW, 3-bolt bracket for all AMC 258 i6 / 4.2l and 4.0L 1999 and earlier Wrangler TJ and YJ.
• S2572-LHW, 7-bolt bracket for all AMC 258 i6 / 4.2l and 4.0L 1999 and earlier Wrangler TJ and YJ.
• B2883-LHX, 3-bolt bracket for 4.0L Cherokee receiving a 4.0L engine from a 2000 or later TJ/LJ.
• S2883-LHX, 7-bolt bracket for 4.0L Cherokee receiving a 4.0L engine from a 2000 or later TJ/LJ.
• B2883-LHW, 3-bolt bracket for all 2000 or later 4.0L TJ/LJ.
• S2883-LHW, 7-bolt bracket for all 2000 or later 4.0L TJ/LJ.
All Brown Dog Offroad high-performance motor mounts and motor mount lifts feature choice of replaceable Classic Polyurethane or Ultra-Flex Rubber bushings.
About Brown Dog Offroad – Born of a broken original engine bracket, miles from civilization on the old mining trails in Arizona’s Superstition Mountain Range, Brown Dog Offroad engineers and manufactures high performance motor mounts, motor mount lifts and engine brackets for Jeep Cherokee, Comanche, and Wranglers. All Brown Dog Offroad motor mounts and engine brackets are made in the United States and backed with a lifetime warranty. For more information go to www.browndogoffroad.com.
Read More | Digg It | Add to del.icio.us
More...
