Jeep JK Snorkel
Im Not Spam
News Posting Bot
Jeep JK Snorkel
Keep's the dust and water out!
AT LAST, A SNORKEL FOR YOUR JEEP WRANGLER JK
ARB USA now offers a Safari Snorkel System for the popular Jeep Wrangler JK. This new accessory serves two primary functions that JK owners will appreciate when taking their vehicle off-road. First, and most obvious, the Safari Snorkel relocates the factory air intake position approximately 28" higher to prevent water ingestion when negotiating stream crossings. Even in relatively shallow water, the nose of the vehicle can easily become submerged as the front wheels drop into a stream or water hole and the rear wheels still on high ground.
Second, and easily overlooked, the Safari Snorkel System is extremely advantageous for vehicles that are regularly driven in dusty conditions, especially when following other vehicles or driving in a convoy. As vehicles before you stir up dust and debris from the road surface, a heavy cloud of airborne particles tends to hover just a few feet above the ground. As your vehicle passes through the dust cloud, the factory air intake tries to draw the contaminated air into the engine. While a quality air filter will block the majority of dust from entering the engine, the air filter can quickly lose its effectiveness if it becomes clogged with debris.
Aside from the risk of becoming stranded in a remote location, the Safari Snorkel System can prevent costly engine damage to vehicles that are regularly exposed to off-road conditions. Additionally, by drawing air from a higher position, your engine will be treated to cooler, cleaner air with higher density. Not only will this prevent damage to your engine, it may actually cause a noticeable improvement to performance and fuel economy.
All Safari Snorkels are manufactured of UV stable, crosslinked polyethylene for the ultimate in strength and durability. Stainless steel and plated mounting hardware is used exclusively for corrosion resistance. Safari's unique evacuation system effectively disperses rain and unwanted moisture and high flow design ensures air supply in excess of engine requirements.
FEATURES
- UV stable crosslinked polyethylene body for the ultimate in strength
- High flow air ducting & body ensures air supply in excess of engine requirements
- Each component is designed for maximum dust & water sealing
- Stainless steel & plated hardware for corrosion resistance
- Fully compatible with optional 7" or 10" precleaners - most models
- Unique evacuation system effectively disperses rain and unwanted moisture
- Completely Australian designed & manufactured
Part No. Description Retail
SS1060HF RH Drive Wrangler JK Snorkel - 3.8L V6 & 2.8L Diesel $521.98
SS1066HF LH Drive Wrangler JK Snorkel - 3.8L V6 & 2.8L Diesel $477.72
About ARB
ARB Corporation Limited is Australia's largest and industry leading manufacturer and distributor of quality, 4WD vehicle accessories, with distribution in more than 100 countries worldwide. The company manufactures and stocks the world's most respected and sought after brands including ARB Air Locker locking differentials and bumpers; Old Man Emu (OME) customized suspension systems, IPF high performance lighting, and Safari snorkel systems. ARB's Seattle office is the North, South & Central American headquarters and importer of ARB 4x4 Accessories.
Read More | Digg It | Add to del.icio.us
More...
FEATURES
About ARB
More...
