Jeep reveals annual Moab Easter Jeep Safari concepts
Im Not Spam
News Posting Bot
Filed under: Aftermarket, Concept Cars, SUV, Jeep, Specialty, Design/Style, Off-Road
Jeep has unveiled its annual spate of concepts before the Easter Jeep Safari. Those start with the Grand Cherokee Trailhawk Concept (below left), complete with the company's EcoDiesel V6 engine. Designers threw in a set of 35-inch Mickey Thompson tires wrapped around 17-inch Rubicon wheels, and a set of custom fender flares help keep all that rubber under wraps.
Meanwhile, the Wrangler Mopar Recon (below right) packs a 6.4-liter Hemi V8 good for 470 horsepower. All that grunt gets to the ground via a five-speed automatic Transmission and a set of a Dana 60 axles frond and rear with 4.10 gears. The Recon also makes use of a 4.5-inch prototype long-arm kit and a set of prototype eight-lug bead lock wheels.
The Wrangler Stitch (below left) builds on the momentum of the Wrangler Pork Chop Concept. Engineers once again set out to strike as much weight as possible from the vehicle, and actually managed to trim the curb weight down to 3,000 pounds. That effort has given the machine the same power to weight ratio as the Grand Cherokee SRT8. Plenty of carbon fiber, door deletes and a chrome moly roll cage all help trim those pounds, and a set of DanyTrac Pro Rock 44 axles with 4.88 gears and ARB lockers front and rear let this machine scramble over whatever is in its path.
The Wrangler Sand Trooper II (very top) gets its grunt from a 5.7-liter Hemi and puts all 400 pound-feet of torque to the ground via a set of eight-lug portal axles. That hardware allows the Sand Trooper II to run 40-inch tires.
Jeep took a different approach with the Wrangler Flattop (above middle), however. With an upscale appearance, the Flattop boasts a chopped windowless hard top that shortens the machine in height by a full two inches. Designers also cut out the B pillar for a massive side opening. Katzkin leather seating indoors helps offer up a bit more refinement, and the Warn Zeon winch and 37-inch Mickey Thompson tires give the rig some added capability off road.
Finally, the Wrangler Slim (above right) is likely the most accessible of the whole bunch, showing off exactly what can be built out of a Wrangler with a little patience on a budget. The Slim features a 3.6-liter V6, axles with a 3.73 ratio, 17-inch prototype wheels and a 10th-Anniversary Rubicon front bumper. Rock rails and a two-inch lift help get the Slim off the ground.
Check the full press release below for more information on all six rigs.Continue reading Jeep reveals annual Moab Easter Jeep Safari concepts
Jeep reveals annual Moab Easter Jeep Safari concepts originally appeared on Autoblog on Wed, 20 Mar 2013 12:44:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
More...
More...
