    To dismiss this notice
    click the top right X.
Jeep Wrangler JK Parts
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Beefing the cross.
OR-Fab’s new heavy-duty crossmember #87034 replaces the weak factory unit found on ’07-‘11 Jeep JK Wranglers. Made from 3/16-inch steel plate, and featuring a fully box welded construction, OR-Fab’s crossmember is 50 percent stronger than the factory unit and uses DOM inserts that also strengthen its mounting points to the vehicle’s frame. The slim design also provides an additional 1/4-inch of ground clearance for greater mobility over large obstacles, and to avoid getting high-centered.
The OR-Fab heavy-duty crossmember comes in a black textured powdercoat finish and takes only 35-45 minutes to install. The kit even comes with 1/2-inch stainless steel button head bolts that allow your Jeep to easily slide over obstacles and withstand serious abuse that would normally dent and twist the factory crossmember out of shape.
For more information on OR-Fab Jeep products that are made in the U.S.A, contact Performance Automotive Group, P.O. Box 3450, Chino Valley, AZ 86323. (928) 636-7080. Or visit www.orfab.com
Jeep Wrangler JK Parts | Digg It | Add to del.icio.us
More...
