Jeep Wrangler YJ Spring Over Parts
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Rock Krawler Suspension has released their YJ Spring Over builder parts section. They are some of the longest spring mounts in the industry, which is one way to minimize spring wrap! They also feature adjustable cross pins which is another great way to minimize spring wrap that no other manufacturer currently offers! Each spring over kit comes complete with (2) spring mounting pads, (2) spring retainer plates made from 5/16-inch thick steel, (4) u bolts, and (4) cross pins! There are three kits available depending on which axle is being used.
RK02979 is to be used for spring over applications for the stock Dana 30 front only.
RK02980 is to be used for spring over applications for axles with 2 5/8-inch diameter axle tubes which is most Dana 30 and Dana 44 applications.
RK02981 is to be used for spring over applications for axles with 3 1/8 to 3 1/4-inch diameter axle tubes which is most Dana 60 or Ford 8.8 axles.
The retail price on each kit is $279 and the Map price is $249.
Rock Krawler has also released a bolt in drag link specifically designed for spring over applications that has a quick adjuster for easy centering of the steering wheel and is made from 1 1/2-inch solid alloy steel! The spring over drag link is designed to be used with the OEM tie rod and is recommended to be used in conjunction with a standard YJ drop pitman arm. It is a plug and play unit with the OEM TRE at the pitman arm. The retail price is $179 and the MAP price is $169.
Also, Rock Krawler has added tons of new components to each vehicle platform on thier website. As of 2010, the retail price of our TJ and LJ systems will be reduced significantly.
Rock Krawler, [FONT=Arial, Helvetica, sans-serif]518.270.9822, [/FONT]www.rockkrawler.com
Read More | Digg It | Add to del.icio.us
More...
