Jegs, Universal Steering Column
rfullington
Thomasville
'80 CJ5, 258
Now that I am into the steering column rebuild, I realize the PO lost some parts when he tried to install a rack and bearing kit. I am wondering if it would just be easier to get a universal steering column from Jegs.
https://www.jegs.com/i/JEGS/555/70464/10002/-1
I do not want to do a lot of mods to make something work if I don't have to, but this seems to be reasonably priced compared to OEM rebuilds.
Has anyone had experience with installing one of these universal columns?
Do you mean "Rack and Pinion" kit? I'm not sure what a rack and bearing kit is, but I havn't done much steering stuff yet.
Also don't forget that you will have to move your ignition to the dash as those columns don't have the key switch. I was looking at one of those tilt units for my CJ and noticed that. The one you linked doesn't have it either.
No, Not rack and pinion, rack and bearing kit goes in the steering column within the tilt collar. When you turn the key, the rack pushes a lever to the ignition on the collar. Mine was broken so when you turned the key the lever would not push down and engage the ignition. I was having to push it with a pair of pliers then jump it at the solenoid to crank it.
https://www.amazon.com/Steering-Column-Tilt-Bearing-Rack/dp/B00ADWKEXI
Yeah, I noticed later that that column does not have a key. Not sure I am interested in relocating the key to the dash right now. I found one of the missing pieces in the column online. It is a preload spring.
https://www.opgi.com/el-camino/PP00282/
I am going to order it and see if I can get this column put back together. I am having a hard time getting the new upper and lower bearings from the kit to go back in the column. I know they are supposed to be snug, but wow! Anyone have a good idea/procedure for getting the bearings in place? Is there a tool that presses them in place?
Thanks!
