Jerking at 40mph and only in 3rd gear
ACK78cj5
Nantucket MA
'78 CJ5,258
New to forum..trying to resolve an issue. New Weber dbl barrel carb installed, idles fine and took it for a drive only to find that when it hits 40-45mph in 3rd gear it jerks and sputters. No issues in first or 2nd gear. Not sure where to begin but thinking fuel pump or vacuum hoses? Thanks!
From what I understand, the Weber needs 3-3.5 p.s.i of fuel pressure which a CJ fuel pump puts out a bit more than that and might require a fuel pressure regulator. You should refer to the Weber instructions or check that out online. Another possibility is that you are not getting enough pressure from a bad fuel pump. A fuel pressure gauge would help here.
I did the same Webber install. Had issues of too much fuel entering bowl, so much so that it poured out the vent when idling. Added a fuel pressure regulator set at 3 psi. Problem solved. Jeep runs like a top!
I appreciate the feedback. I adjusted regulator to 3.5 psi and issue was resolved! Thanks for your help!
