    To dismiss this notice
    click the top right X.
JK 44 Front Housing Replacement
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
New JK Upgrades.
TeraFlex JK Wrangler Tera44 Front Replacement Axle Housing
Murray, Utah- October 28, 2011. TeraFlex Inc., manufacturer of TeraFlex suspensions, body protection equipment, low range gearing and HD axles, introduces the newest heavy duty component for the JK Wrangler.
The TeraFlex Tera44 heavy duty front Dana 44 replacement axle is the perfect solution for bent, broken or damaged front axles in JK Wrangler Rubicon vehicles. This replacement axle can also be used to build a heavy duty axle upgrade for non-Rubicon JKs.
The replacement housing includes a heavy duty Tera44 housing, tubes, inner seals, axle bracketry, and outer knuckles. Simply transfer your existing internal components, outer knuckle assembly, and brakes to the new housing!
The Tera44 has the following features:
• Ductile cast iron housing with increased rib gussets
• Smooth radius bottom design to glide over rocks & obstacles
• Asymmetric housing design, for long tube side strength
• Bottom oil drain hole for simple fluid changes
• Integrated factory location upper control arm mount
• 3.25” x 0.25” axle tube to resist bending and torsion with minimal weight increase
• ¼” thick CNC laser cut axle brackets for extreme strength
• Compatible with factory JK Rubicon locker
• 100% engineered, designed, and built in the USA
• 100% new components
• No Excuses warranty - 1 year, unlimited mileage
The TeraFlex JK Front Replacement Axle Housing has a retail price of 2049.99.
TeraFlex products are available direct, or through authorized TeraFlex Dealers. For a complete list of Dealers in your area, or to purchase direct, contact TeraFlex at 801-288-2585 or visit them on the web, www.teraflex.biz.
About TeraFlex - Since 1997, TeraFlex has had a dominant hold on the Jeep market. TeraFlex was the first suspension manufacturer with a suspension system for the TJ Wrangler, and is still the only aftermarket company to offer a solution for the venerable 231 Transfer Case ’s low range gearing. Continuing their stronghold, they offer the most comprehensive list of performance components for the JK Wrangler of any other manufacturer to date.
JK 44 Front Housing Replacement | Digg It | Add to del.icio.us
More...
