oldjeeplady,
Here are some more, this guy had a Viking winch in the front that I wanted to move up and forward (he is spooling off the top) to put a regular Saginaw box up front w/ a newer
CJ5 mount, but he got hooked up with "Herm The
Overdrive Guy". So he got the Bronco style box above the axle, I said sell it and get the right stuff and I will move the winch how it should be, he did not want that. He also got the wrong DS Exhaust so had to find one of those also. Instead of wiring a `66 to the Saginaw I put in a used 1980
CJ5 wiring harness and scrapped the old.
This next Spring I am going back to Glendale, AZ to rebuild his
Transmission /
Transfer Case , new springs, shocks, shackles, DL`s and put newer
CJ5 11" brakes w/ e-brakes on. He is in failing health and wants to spend his time wheeling the desert with his grandkids, and leave it with his oldest.
P.S. when I took the intake off there was casting slag in the heads, so he got a quick porting job for free.
