Leaf spring track bar
Purple77CJ7
Full Time Jeeper
- Media
- 36
- Loveland, Colorado
- 1977 CJ 7; Amc 401 .30 over, Howell TBI, modified Dana 20 with Terra Low gears and twin sticks, NV 4500 5-speed, modified Dana 30 and Amc 20 both with 4.56 gears (narrow track), ARB air lockers front and rear, SSBC rear disc brake conversion, MICO Brake park brake, Navaho brake booster/ master cylinder, PowerTank CO2 tank.
I used a JKS YJ adjustable track bar and cut it down 8" to fit my narrower frame. Made a mount on the frame and the top of the diff. I should have rewelded the C'S to the correct caster angle. At the time this seemed easyer and it has worked well for a few years now. You can lock it down tight for driving on the road then loosen the bolt in the middle and it allows it to slide so you don't lose articulation. It stopped the death wobble.
