Leafspring SHIM Question
project74
when installing a degree shim between rear axle and spring pack...the center bolt on spring pack normally locates into the hole on the axle pad to secure it from movement...but when using a shim, the center bolt is too short to teach thru the shim to the axle pad, therefore not securing the axle to spring location...would'nt it be a better idea to replace the spring pack center bolt with a longer one (grade 8) so it DOES reach all the way to the axle pad?
any thoughts are appreciated...
Ed..................it's the weekend so get in the shop!
