lifting my first jeep
I agree with all this except #2b. doing a tie rod flip will not work with a SOAI'm gonna get on my soap box about SOA's..
Pro's: Cost for the soa spring perches.. Less then $100. If you can weld your self then it's really cheap.
Cons
#1..it will give you 5-6" of lift which is way more then you need for 33's. Figure 2.5" for the axle tube +1-1.5" for the new spring mounts + 1.5-2" for the spring pack.
#2.. The steering will make contact with the springs since they are now above the axle. This can be addressed by a) just driving it b) tie rod flip cost about $100 for the kit c) some stupid looking S or Z bar linkage which are weak and know to fail or d) convert the front passenger side knuckle to high steer which is going to set you back around $600 but that is he best and most correct way to fix the steering.
#3.. If the steering is left in the stock position you will probably end up with a crazy about of bump steer. Google soa steering problems.
#4.. Axle wrap. With the soa the springs are more susceptible to axle wrap.. Again google it. That can be fixed by installing a anti wrap of ladder bar.. Another $AMC 150 -200 to set one up if you know how to do it.
Please don't get me wrong. It this was a designated mud or trail rig then you would be ok because to don't go fast enough for the steering issues to bother you.. As a daily driver I think you would be very unhappy. If they are done correctly and steering/anti wrap is addressed you are looking between $1000-1500 which is way more then a good sua spring set up.
Fortunately it's your jeep.. You can do what ever you like with it.. If some one is trying to sell me on a cheap idea I normally try to check out the pros and cons..
I want to lift my 69 CJ5 . should I go 2.5 inches or 4 and if I go 4 do I need modifications to the manual steering, a drop pitman arm, etc.?
Harley you obviously know what your talking about and how to fab things to make them right. Unfortunately when giving advice to some one on these forums you need to look into Thier question and see exactly what they are asking. For example
To me this states I'm new to jeeps and 4x4's and have little to know experience. Which is fine since we all start out there. I would take this as sign that he does not have full fab shop at his disposal so he will have to pay for labor and the expertise of some one like your self to do the work for him.
I have a few metal fab shops locally and the all have a no work on vehicle policy to keep from liability if their work fails while your driving down the road so to get that type of work done here you have to go to a 4x4 shop where they are comfortable with bending you over before they do your lift. Great thing about the internet and forums is we all get to share of vast array of information that we have done, seen work and seen failed. I'm lucky enough to live in an area that has a petty big area set aside for riding and I get to see plenty of horrible things done on 4x4's and the number one thing is improperly set up soa's
If you can do a soa with out any other mods to the front axle then you need to share with us your secrets. I definitely be interested in seeing how you modified your Dana 30 front end to not crumble under the power of that motor and 37" tires.
Jimbo,I think that if you will look back through this thread you will see that you are the one that climbed up on your soapbox,as you called it and gave your viewpoint of spring over lifts.I simply responded with my own views,not from what I had heard or read,but,from first hand experience.
Also,if you will look at my first post after you got off your soapbox you will see that I recommended that he go with the 2 1/2 inch lift and not try a springover.I might be fairly new to this particular forum but you can bet,this ain't my first rodeo
