Liquid Check Valve
Ok Jeep gods, found another potential problem...
I have a 74 CJ5 , with a AMC 304 that I bought about six months ago... When I bought it, the fuel gauge never worked. So today, I dropped the fuel tank to change the fuel level sender... The tank dropped really easy, cleaned up nicely, all complete with a new fuel level sender... I found the problem to be the ground was no longer connected to the old fuel level sender... But now, on to the curiosity...
In my inspection with the fuel tank dropped, I traced the fuel lines, vent lines, etc... I noticed that the liquid check valve had all three lines connected to it... As I was following the one line that leaves the check valve, I noticed that it was capped off... Upon further research, it appears that this line should go to a charcoal filter, which is no longer installed in Jeep... I also noticed that no rollover valve was never installed...
So... Here it comes... Should I leave things the way they are?!? No rollover valve and a liquid check that is plugged off... Or should I buy a rollover valve and charcoal canister and install them?!?
