Looking for advice - flywheel and clutch.
CMack
- Media
- 47
- Helena, MT
- 1960 CJ5. 134 F Head
T-90 transmission
Dana 18 transfer case.
At another point where I need some advice and experience.
I have the engine out and the bell housing off. The block is ready to go to the machine shop.
Questions: how does the pressure plate and flywheel come off? Here is where things are now.
Do I need a puller to get the flywheel off, or will it slide off?
There are some teeth with some gouges in them. Should this flywheel be replaced?
What should I look for in the pressure plate and throwout bearing in terms of wear, replace or still serviceable?
When it comes to reinstall, does the flywheel need to be aligned a certain or does it not affect the timing?
And finally, does anyone know the torque specs on the flywheel and the pressure plate?
Thanks in advance.
Thanks in advance.
