Loose steering of front 35's - Listening for the voice of experience.
DHugg
- Media
- 46
- Resources
- 1
- MS Gulf Coast
- '80 CJ7 304AMC crate with 8KMiles: MC2100 - AMC20 rear w/Superiors - Dana30 front - TF999 - Dana300TC - 35x12.5's - Tilt steer column - Flaming Rvr EZ-Steer Shaft - AGR Super Pump - AGR Super Box II - RockyRidge HD Brace - New home-designed digital TEMP - GAS - OILPR - CALIBRATE gauges.
I'd like to hear from people ("guys" no longer covers the waterfront, does it?) who have reworked worn-out front ends.
1980 CJ7 304CID with 35's seems to have been much of its life in the West, among rocks. There are rock scars on the pumpkin and other places. I've replaced the PS pump, the box, the 2-piece box mount with a HD single piece, and installed a heavy brace on the steering box shaft housing. That helped a serious sloppy steering condition for a time, but it has crept up on me again. This ride gets me into places I couldn't otherwise reach to set crawling crittur traps for biological research.
I'd like to run it until Christmas when it gets cold enough to pull the crittur traps until spring (Gulf Coast 30 degrees N). I have a set of Timkens for both wheels, and Spicer ball joints for both, but I would like to bandaid the damage until a full teardown.
Where is the most likely place to reduce front wheel wandering? If the answer is either tie-rod and drag link ends or wheel bearings, I can work that over a weekend. If it is ball joints, then I'll bite the bullet and tear down each front wheel and axle for a complete fix.
I think I need more than one Jeep, but if I say that out loud I may as well have said "more than one wife". I know enough to be careful what I wish for.
Appreciate any feedback for those with more experience (with Jeeps) than I.
