Loose windows in Acme Hardtop
rocmoc
- 1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
The door alum window frames are loose in the fiberglass hole. I have the driver window out. I am either going to use strip caulking or rubber foam strip between the frame & fiberglass. What ever was there is gone so no idea what was there from Acme. Any better suggestions or recommendation? Or can you see what is between your window frame and the fiberglass. Thanks!
rocmoc n AZ/Mexico
rocmoc n AZ/Mexico
