Lower housing shroud.
Vikingone
Lake Worth FL
85' CJ7, 4.2 Liter, swapped in T18
I have an 85 CJ7 and am replacing the bearing in the tilt steering column. And upon reassembly I found that the key release lever wouldn’t work. Ultimately I found the plastic nipple on the lower shroud housing where the spring sits broken. I’ve tried looking online for another shroud and have had no luck. Does anyone out there know where I could find one? At this point it seems as though my only options are to install a push button start.
Find a ratty tilt column for parts.....
