Lower Steering Column Bearing Removal
ottis
- Media
- 2
- Grass Lake, Michigan
- 79 CJ7, Fiberglass body one piece tilt front end, 79 425 Caddy, T18 trans, Dana 20 transfer 44 rear, 30 front (dumped the loc outs) with 3.02 gears, rear disc (using front calipers so i use same parts front and back), 2" spring lift 1.5" body
i have a 79 CJ7 and the lower Column bearing race is rusted to the shaft and i'm looking for an easy way to get the shaft in the column out to work on the seized bearing race. The shaft with the siezed bearing race "shuckes" in and out about 3/8 of an inch but the steering wheel doesn't move. Is this "normal"?
