lower steering shaft replacement ?
RMB
Orlando,FL
Hi:
I have a new lower streering shaft that I plan to install.... Is this pretty basic install? (Manual steering).
Thanks!
Are you talking about the shaft from the column to the gear box? It's just a bolt off and a bolt on... The lower part does have a weird clip.
Where did you get the new shaft? Most aftermarket shafts come with pretty specific instructions.
