Mc 2100 ?
Rusty Shank
- Chino California
- 1978 cj7 golden eagle
304 with a automatic trans, Quadratrac w/Hi-Lo BW 1339 transfer case
3.5 lift. Rear locker 32in tires
Power steering. Front disk breaks drum in the rear.
3 core radiator
I found out that i am missing the weight that sit on the discharge ball so i pick one up on the way home frome work and put it in and now the accelerator pump will not spit fuel out. I pulled it out and now the weight has a little bend in it from were i screwed the venturi screw in. how long are these weights and are they tight against the ball or is the weight free to move up and down inside the venturi screw.
