MC2100 with cracked venturi
CJ5MArshall
Marshall VA
65 CJ5 with 71 AMC 304
I have the 71 AMC 304 and the MC2100 1.08. I tore into the carb to clean and rebuild. Upon dis assembly I found that one of the venturi tubes is cracked the length of the tube. I have a few questions. Is it possible to clamp and solder the tube? Would a 1.21 venturi run with this set up. I have done some research and found that some people have run the 1.21 on the AMC 304 successfully. I have found replacement 1.21's but not the 1.08. So my third question is if anyone has the 1.08 venturi they would come off of? Thanks for the help in advance.
:ww::dbanana::banana:
IF, the tube is brass. You can try to solder. Use 60/40 rosin core. ;)
You will need to drill the inside of the tube back out to the OEM, I.D.
Check with Mike, he has the 1.25 venturi he may also have the 1.08
A lot of ford cars have the 1.08 mc2100
Motorcraft 2100 1.25 Venturi
I actually ordered the 1.21 from Mike. I spoke with the place that rebuilds the carbs for them and was told the 1.21 will fit. It will take some tuning, but at least its a 40 dollar part vs. a reman carb. I will post with results when I get it. Thanks for the suggestions.
