MORE Shackle Installation Help
jafo
Old Time Jeeper
Ok. Puting a 4" lift on '79 CJ7 . Got tha back almost done but need info on these rear shackles install. I have them on. I'm trying to figure out how tight they need to be. This shackle are the greasable with the center solid spacer. There was no install instructions so I used the trail master instructions and it calls for fron and rear springs bolts tightened to 80 ft lbs. I started to do this to the rear MORE shackle and it started to bend inwards so I stopped and backed off. I just tightened the top and bottom bolt to the point where the shackle side just started inwards. Is this enough? If I go to the 80 ft lbs it'll ruin the shackles I'm sure. Anyone run these that could give me some advice on the tightening of the shackles?
