Motorcraft 2100 with 1.14 venturies on 258
Bent
- Media
- 12
- Solutions
- 1
- Olympic Peninsula
- 1982 CJ5, 1978 258, T177, Dana 300, AMC 20, Dana 30
Hello, I submitted this on another forum and got no response.
I'm in the process of converting from a Holley 2300 (350 CFM) to the Motorcraft 2100 on my AMC 258 i6 / 4.2l .
It seems like most people recommend the 1.08 venturi size for the AMC 258 i6 / 4.2l . I have a 1.08 and a 1.14. I assumed that the 1.14 was a larger carb based on the fact that it has larger venturies and flows more CFM. It's not! The 1.14 has smaller throttle bores t han the 1.08! Information on throttle bore size for these carbs is hard to find. But sitting next to each other it's obvious. It looks like the 1.02 and the 1.14 share a common bore size with different venturies. And, the 1.08 and the 1.21 share a common bore size. A smaller bore should increase air velocity through the carb and not just at the venture . This should improve low RPM torque and provide a stronger vacuum signal at the vacuum advance port.
I would like to hear from anyone that has run has run the 1.14 on a AMC 258 i6 / 4.2l . It's a 1978 AMC 258 i6 / 4.2l with a mild cam, HEI and a 1986 cylinder head. And no, I don't want to switch to a Weber. I believe annular discharge boosters are a better design for a low RPM motor.Thanks for any replies.
