    To dismiss this notice
    click the top right X.
Mounting Tires At Home
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
Backyard Beadlock InstallOne of the cheapest and simplest ways to improve your 4x4’s off-road performance is to reduce the air pressure in your tires. When you lower the pounds per square inch (psi) inside your tire, it allows the tire to flex and grip the terrain more effectively. For light-duty wheeling a traditional tire and wheel set can safely be aired down to 12-15 psi. While those air pressure numbers may seem low, on today’s Load Range D and E tires they often barley put a bulge in the tire—especially when mounted under a lightweight rig like a Jeep Wrangler. To get the most performance out of the tire while safely running extremely low air pressures, a beadlock wheel is an excellent upgrade.
Photo Gallery: Mounting Tires At Home - 4-Wheel & Off-Road Magazine
Mounting Tires At Home | Digg It | Add to del.icio.us
More...
