    Thank you for your support!
Muriatic acid on metal before por15?
jamie411
Canada
1983 CJ7
Muriatic Acid. AKA hydrochloric acid.
Has anyone used this before applying POR15?
Rather then the metal ready suggested by POR15?
curious.
I have used the acid prior to regular paint it kills the rust well...andd I have used the POR 15 without any prep and it worked well as well. The muraitic acid will remove the rust but I dont think there Metal Ready does
Excellent,
Thank you for the response.
Did you use the acid and then wash the remaining off after you were done? or just paint right over the acid?
If you use any acid on any metal you have to neutralize it before you paint over it.
If you are going to use POR15, just follow the directions they specify. The system works... It encapsulated the rust an stops it.
