Build Thread My CJ7 build thread
derf
- Cedar Rapids, IA
- 1984 CJ7 - 5.3/4L60E/Atlas4spd/D44/9" - In Progress
1984 GW - 360/TF727/NP229/D44/M23 - NP242 swap in progress
1986 J10 - 360/TF727/NP208/D44/D60 - 700R4 upgrade in the works
So rather than mix all my posts into other threads, I figured I'd make my own thread.
If you want to see what I've done so far, or you just want to see the whole build progress, go here: My 1984 CJ7
Today I built my Transmission crossmember. I used 2x3 rectangular tubing and used the captive nuts in the frame that the original skid plate bolted to. I had to notch one piece to clear the parking brake bracket and I had to do some creative tapering of the cross tube to clear one of the bolt holes on either side.
I still need to clean it up and paint it but it's holding up the transmission now. I'll get to it when I drop the transmission to get the clutch installed.
