My First Welding attempt to fab an exhaust for my engine swap went well.. so far
76cj7chick
Old Time Jeeper
- WA
- 1976 CJ7 Jeep with a engine/tranny/wiring harness out of a 1988 s10 blazer 4.3l v6 with th700r4 automatic tranny and a cj7 Dana 300 transfer case with Novak adapter.
Complete wiring harness from the s10 blazer. Painted with HOT PINK Pearl paint with standard sized metallic halographic pink flakes. Painted by me -a newb. New rear, front and side three wire LED lights, New parts, new custom dash-by me And a lot of guidance from fellow jeepers and lots of prayers etc.... :p
Hey guys!
I am nearing the end of my (everlasting) engine swap....
After much reluctance, (fear) I decided to give it a try and fab and weld my own exhaust system.
Had some issues along the way...Like when the bolt broke off in the intake manifold. But I managed to drill it out and "rethread" the IM. So far its working great.
I ended up buying a kit of mandrel bent, straight and flared end 2.5" exhaust pipes off ebay. And a "Y" oe down pipe, exhaust gaskets, new bolts and exhaust clamps and walker hangers off amazon.
I just had to cut and fit each piece. The "Y" exhaust pipe came off the exhaust manifolds and united together on the passenger side where I had to cut some off so it wouldn't run into the transfercase crossmember. Then, I had to bring it through to the crossmember to the back and cross it over to the driverside to the muffler (I ended up buying a Magnaflow 3.5" and two reducers to fit it to my new exhaust).-I'm hoping this is okay and won't cause any issues since its wider diameter than the stock muffler...It sounds good...But please let me know if it's hard on the engine.
The mandrel flared exhaust pipe kit was very helpful in connecting the pieces. The flared one end allowed me to double check each ection for proper fitment. (And to make sure the pipe avoids hitting other components.) I then watched more videos on how to weld. My neighbor also stopped by and briefly showed me how to weld....
I then gave it a go on my own.
To my pleasant surprise and happiness, I did okay. And the exhaust was done.... Well almost....
QUESTION:
Although I welded most of the pipes together (three easy to remove sections) I don't want to weld the muffler to the exhaust pipes so I can remove/replace easily. And I am thinking of using permatex ultra copper gasket maker and then two clamps.... Anyone think that's a good and workable idea? :0
Thanks bunches...
QUESTION:
Thanks bunches...
