My rear shackle hanger came unbolted!
ThisGuyUKnow
Full Time Jeeper
- Harleysville, PA
- 1986 CJ7 Laredo 4.0,Nv3550,D300 Twin Stick,AMC20 3.31, 31 BFG
Honda vtx1800c
Well I am not sure what happened but it looks like the bolt fell out on the pass side and on the driver side the bolt is loose and when I try to tighten it it just spins. SO that is some bad hat. I am slightly at a loss on how to fix it. It looks like i need to replace the nut inside the frame. My general plan is to drop the tank so i can get to the bolts that hold my Bumperettes and then just drill a hole straight through the cross member under the tail gate. I doubt I will be able to get it big enough to get a wrench in there but may I can get enough grip on the bolts to tighten something back up?
DOes anyone have any ideas?
