Mystery Axle and drum to disc conversion
- Orlando, FL
- 1985 CJ7, AMC 360, lunati cam, AX15, Affordable Fuel Injection, edelbrock performer manifold, 21 gallon fuel tank, Old Man Emu 2.5 inch lift, 1 inch body lift, tie rod flip, HMMWV H1 steering box, rear disc brake conversion, Dana 44 rear, YJ to CJ tub conversion, still working on 33 inch tires, Metallic dark blue paint.
Scrambler Project, cosmetically taking it back to the 80's- 1984 Scrambler, Laredo. 258cc, Holley Sniper EFI, 30in tires on Laredo polished wheels, Dana 44 rear, OME 2.5 YJ springs/lift, HMMWV steering box
Previously owned cj 7, 1979, Renegade, 258 and a '89 wrangler
Since I have an 85 CJ7 I assumed that I had an AMC20 . I ordered the parts and started the process to convert the drum to disc brakes.
The problem was that the parts didn't seem to fit. The bracket was too small and the bolts appeared to be too large to fit through the bracket.
Then I realize that maybe I don't have a 20, maybe it's a Dana 44 or 60. I text the previous owner who sold the jeep for his dad, who has since passed away and he confirms that his dad did "upgrade" the axle, but he doesn't know what kind or from what.
I google the picture and it looks like a 44, but why would he trade them out?
I have already cut most of the back plate for the drivers side so I'm at the point of no return.
Anyone have any advice on what kind of axle this is, how I can ID it and how I can successfully continue with the conversion? Should I just get a Ford Axle with the disc already on it?
Coincidentally someone started a thread this morning about converting a 44, so if it is a 44 I will follow that thread to see what I can learn.
The one solution I thought of was to continue with what I have, grind the bracket to be wider, Make the holes bigger, and in picture 4 you can see that the fabricated bracket won't sit flush against the drum plate backing, maybe I could fabricate a piece of aluminum or steel from a clay impression to fit into that "valley in the backing and allow the bracket to sit flush
thanks
thanks
