i have a 78 CJ5 . right now it has the stock 3" wide leaf springs in the rear.. is there any difference in putting the narrow springs in the rear? and what all will i have to change??
73 CJ5 4.0 head on a 258, HEI, Holley Projection w/ 4.56, Detroit lockers Narrowed D44 front and full float D44 rear T14 w/ D20 4 wheel discs, 38.5 Boggers
I don't understand why you would even consider putting 1.75" wide springs on. Ask any Pre-76 CJ guy. But if you insist, spring hangers and spring plates. Need some spring plates?
83 CJ7 350 tbi, TH350, D300 twin sticked & clocked, narrowed Chief D44 Eaton Elocker & Moser shafts, Explorer 8.8 Detroit locker, 410's, RE 4.5" spring lift 1" body lift, 35" Claws, cage tied to frame, Corbeau baja seats, HD tie rod and draglink, u-bolts flipped, custom skid plate and sliders, Warn 9.5ti winch with Amsteel synthetic line
