Need help choosing shocks
DaveMueller
- Media
- 1
- Ohiopyle, PA
- '76 CJ5 with an '88 258 from a YJ.
AMC20, D30, D20, T150.
So my front shocks are shot. The suspension is no longer stock thanks to a PO. I don't know how to identify what shocks I should get (based on size, not handling etc).
Shackles are 3.5" center to center, so I think just a little longer than stock (3"?). I don't think the 1/4" lift would affect the shocks.
However, the upper shock mount has been changed. It is much higher at the shock mounting point, and the fender was cut away to fit. It looks like the stock CJ5 mount in the manual, just longer (taller).
The bad shocks have 10" of total travel, 16 to 26". Google didn't find any useful info on the number stamped in the shell.
Tires are 30.5" (265/75-15).
Is there something I can measure to determine min/max for the shocks, and do vendors publish that kind of info?
What's the advantage of using a longer shock if nothing else has changed on the suspension?
If I go back to stock CJ5 upper mounts, will I have problems because of the larger tires?
Dave
Dave
