NEED HELP! shackle "hanger bushings"!?
dinolambchop
Lawrenceburg,IN.
85'-cj7
86'-cj7
98-tj
I have been searching online for the actual "hanger" bushing themselves. The ones on my CJ7 are worn out and im replacing the springs. I ordered what a exploded view on morris off-road told me would be the "hanger bushing". Well they were way to small and don't even fill the hanger hole. I believe they were for the leaf spring eyelet instead actually. I've just purchased warrior shackles, which have a 1/2" hole and require a 1/2" bolt to run threw. Stock hanger bushings are smaller. If anyone could link me to a website to where I could purchase these bushings would be great help.
Thanks,
More info would help. Can you link to the part you ordered. Are you sure a previous owner didn't switch to wrangler springs which use a 1 1/4" bushing instead of the 1" which is std. on a Jeep? Are you wanting rubber or poly bushings?
What Pa said, cj shackle bushings should be 1" OD both top and bottom.
The end without the shackle is 1 1/2" OD.
A lot of people change to the wrangle 1 1/4" to have the sleeve in it.
Measure the hole the bushing is going in and we can help more, I hope.
