CLOSED KNUCKLE PARTS
Spindle Bushing Set
(2 of 3 Sizes currently Available from stock)
Shipping Note: Select USPS mail for the lowest shipping cost on small parts orders.
Bronze Spindle Bushing Set for 1940's to 1982 4x4's with CLOSED KNUCKLES. These bushings were pressed into the spindle on most closed knuckle models. Some trucks also had these bushings pressed into the end of the axle tubes to support the inner axle shaft. Each Kit includes 2 Bushings. Made in U.S.A.
For Specific Application Information, Use the Link Bar at the top of this page to see our Front Axle Page for your vehicle!
QU40321-2 Small Spindle Bushing Set Fits Jeep to 1971 and IHC Scout to 1971 1-1/4" ID $14.98
QU40025-2 Medium Spindle Bushing Set Fits most Chevy, Dodge, Ford, GMC, and IHC 1/2 and 3/4 Ton trucks with Model 44 axles. 1-3/8" ID. $15.98
QU40431 Large Spindle Bushing Fits Dodge, IHC, and Jeep 1 ton, 1¼ ton, and 1½ ton trucks with Dana 60 and 70 Front Axles. Sold individually. $39.97
QU40189
Large Knuckle Ball Seal Kit
Ball Seal Kits
Two Sizes Available
Knuckle Ball Seal Kits for all Dana closed knuckle front axles 1941-1982. Kits include split metal backed ball seal, felt wiper seal, metal backing plates and either 8 or 12 new serrated, flange head cap screws.
Two kits required to service both sides of your front axle assembly. Made in U.S.A.
QU40188 Small Knuckle Seal Kit fits 1941-75 vehicles with Dana 25, Dana 27, Dana 30 , and Dana 44 Closed Knuckle front axles. Seal assembly is held in place by EIGHT (8) bolts. (Limited Supply! ) $34.95
QU40189 Large Knuckle Seal Kit fits 1958-1982 ¾ ton to 1½ ton vehicles with Dana 44HD, Dana 60, and Dana 70 Closed Knuckle front axles. Seal assembly is held in place by TWELVE (12) bolts. $59.95 Limited Supply!
QK4766
Large Seal and Felt Kit QK4766 Large Knuckle Seal and Felt Kit fits same applications as QU40189 sold above, but does NOT include metal retaining plates or bolts. Kit includes one seal and 1 felt
Out of Stock.
QK4616 Large Knuckle Bearing & Bushing Kit
(also available are 2 Knuckle Bearing Kits which have 4 bearings instead of the 2 bearings and 2 bushings shown above)
Large Closed Knuckle
12 Bolts Hold the Seal On
(Dana 70 Axle shown here is on a 1976 IHC 1600 1½ ton School Bus)
QK4617 Small Knuckle Bearing Kit includes 4 knuckle bearings, 4 knuckle bearing cups, & shim kit. Fits Chevy, Ford, GMC, International Scout, and Jeep closed knuckle axles with 8 bolt knuckle seal. Made in U.S.A. Dodge and IHC with splined upper king pins: You will have to have the splines machined off your upper king pins to use this kit. $109.97
QK4616 Large Knuckle Bearing and Bushing Kit for ¾ ton to 1½ ton Dodge, GM, IHC trucks and Jeep M715 1¼ military series Using Dana 44HD, 60, and 70 closed knuckle axles (12 bolt knuckle seals). Kit includes 2 upper bronze knuckle bushings, two lower knuckle bearings, four knuckle bearing cups, shim kit, & woodruff keys. Dan the Gear Man Product Note: The Upper Bushings used in this Kit are in critically short supply and very expensive. For a less expensive alternative, you can use the QK4618 Large Knuckle Bearing Kit sold below. Made in U.S.A. $229.97
QK4618 Large Knuckle Bearing Kit for Ford F250 and F350 trucks with Dana 44HD or Dana 60 closed knuckle axles (12 bolt knuckle seals). Kit includes 4 knuckle bearings, 4 knuckle bearing cups, & shim kit. Made in U.S.A. $159.97
QK4765
Closed Knuckle Shim Kit.
Shims are used between the King Pin Cap and Steering Knuckle to adjust the amount of preload on the Knuckle Bearings. Correct Preload eliminates "Death Wobble" and maximizes the life of the King Pin Bearings or Bushings and tires.
King Pin Shim Kits for Closed Knuckle Front Axles. 2 Sizes available. QU40773 fits all 1941-1975 Dodge, Ford, GM, IHC, and Jeep 4x4's with Dana-Spicer Closed Knuckle Model 25, Model 27, or Model 44 using the small 8 Bolt Ball Seal and rectangular 4 bolt King Pin Caps. QK4765 fits all makes of 4x4 trucks using Dana-Spicer Model 44HD, Model 60, or Model 70 Closed Knuckle Front Axles with the large 12 Bolt Ball Seal. Each Kit includes enough shims to adjust one knuckle on most trucks.
QU40773 Knuckle Shim Kit for trucks with 8 Bolt Ball Seals. Kit includes a variable amount of shims (usually 12-16) with a total thickness of approximately 0.100". Shims may be Made in U.S.A. or imported $14.95
QK4765 Knuckle Shim Kit for trucks with 12 Bolt Ball Seals. Kit includes 11 shims total. (4) .003", (3) .005", (3) .010", and (1) .030".
Sizes are approximate. Made in U.S.A. $19.98
FRONT LOCKOUT (FREE WHEEL) HUB SERVICE KITS AND PARTS 5 Sizes of
6 and 8 Bolt Front Hub Gaskets to Choose From. Precision Cut Original Equipment quality gaskets provide a clean, leakproof seal between the wheel hub and lockout hub on vintage 4x4 front axles. Made in U.S.A.
Dan the Gear Man® Tech Note: All the gaskets shown below are cut from premium quality gasket paper except for QU40395 which is aluminum.
Click on the Thumbnail for Gasket Identification Instructions
QU15005 Small 6 Bolt Gasket fits most 1941-1971 Jeeps with 6 bolt external mount hubs and 1972-1980 Jeep CJ5 , CJ6 , CJ7 . 3-7/16" Bolt Circle. Also fits IHC Scout 1960-1970, 1971-1980 Scout II, Scout Terra, and Scout Traveler
(Does not fit Jeep J20, J4800, or M715 series.)
$2.79 each or Save Over 10% by purchasing Online for only $2.49 each!
QU40053 Medium 6 Bolt hub gasket fits most 1950's-mid 1970's 3/4 ton trucks (ID of gasket may need to be trimmed to fit over pilot on some lock-out hubs). 3-3/4" Bolt Circle. $6.59 each or Save Over 10% by purchasing Online for only $5.89 each! (Limited Supply)
FITS:
Chevy K20 to 1960-1977½, GMC K25 to 1977½,
Dodge W100 1987-1968, Dodge W200 1957 to 1974,
Ford Heavy Duty F250 1963-1977½,
IHC ½ & ¾Truck 1956-1972,
Jeep J4800, J20 1972-1977½
QU15006 Large 6 Bolt Hub Gasket fits 1967-1969 1¼ ton Jeep M715 military series, and many late 1960's-mid 1970's Dodge and International 1 ton trucks with Dana-Spicer Axles. 4-3/8" Bolt Circle. $5.59 each or Save Over 10% by purchasing Online for only $4.99 each!(Limited Supply)
QU50216 Dodge 8 Bolt Hub Gasket fits 1976 to early 1991 W350 and 1989-early 1991 W250 with the Cummins Diesel Engine. 3.960" Bolt Circle $6.59 each or Save Over 10% by purchasing Online for only $5.89 each!(Limited Supply)
QU40395 Special Metal Hub Gasket for Spicer Factory Hubs on late 1960's to mid 1970's 3/4 ton Chevy, Dodge, Ford, and GMC trucks with external mount hubs. Gasket fits between the wheel hub and steel hub spacer. 3-3/4" Bolt Circle $19.95 each (Extremely Limited Supply!)
