Need help - Wrangler booster / master to CJ lines
cwiehle0
Brief rundown- I'm installing a fiber tub on 86 cj. Don't have orig cj booster, MC, or prop valve. I bought a wrangler booster setup. I already installed new stainless CJ lines routed and hooked up at wheels. Here's where I kinda don't know what direction to go. The 86's had the prop valve on the frame and wrangler booster I bought has it directly under the MC
Will it be easier to install CJ prop valve so my new lines hookup directly, then run lines up from there directly to the MC eliminating the wrangler prop valve altogether. If so, does anyone predict functionality issues using a wrangler booster and MC with a CJ prop vavle? My other option would be to retain the wrangler prop and make lines that go down to the cj lines
