Need hydraulic clutch conversion advise/guidance
Oldguyinajeep
- Media
- 9
- Derby, KS
- '86 CJ-7 258ci 4spd Dana 30 and 44
Howell TBI Fuel inj, Headers, Dual batteries, Warn winch/air compressor, rear
disc brake conversion, Detroit locker (rear), Eaton E-locker (front), 4:10 gears, 2.5 in Rancho lift, 1" body lift, fully armored, 35" BFG KM2s, Warn front hub conversions, line locks front and rear, roll cage, warn front bumper, rock hard rear bumper/tire carrier, DUI ignition, dual electric fans, LED rock lights
I've finally had enough of spontaneous bell crank dislocation. It's hosed me on the trail at some serious moments, and I'm not going to wait for it to strand or kill me.
I believe instead of putting this together piecemeal, I'll simply buy a kit. I see that Novak and others have nice kits, which get good reviews from other jeepers. I'd appreciate input from the forum regarding experience with and opinions of the different kits.
Also, I have a couple of technical questions:
I've put a vacuum assist power brake system on, and am concerned about clearance on the clutch master cylinder. I can find one posting that seems to indicate that it's doable.
Second, it seems that some folks use a YJ clutch pedal which already has a stud for the MC connection. Some also install a shoulder bolt in their existing CJ pedal. I could do the fabrication, but don't know where to position the bolt.
Any suggestions would be much appreciated.
