Need some advice
I bought this '80 CJ5 with deep snow in mind. I've got a remote place in the mountains and the road is not plowed. I figured big tires deflated to 10 or 12 pounds will get me there. The tires are 13.5 x 35 with some tread on the sidewalls (Toyo Big Country). I installed 1.5" spacers so the tires don't scrub the leaf springs when the wheel is cranked. I've also cut the wheel wells out to the max. The jeep had 33" tires when I got it, so I assume it has been lifted some, but not enough for the 35". It looks like I need to lift the body a couple inches so I don't damage my fender shrouds in the front. The rears look like they'll work fine as is. The jeep is pretty high now and I'd like lift it as minimally as possible. It did fine this summer with the 33s and I had the thing torqued out of shape good on some nasty terrain. Since I'm adding 2" of tire I thought a 2" lift would do it. I'm new to jeeping, am I thinking correctly? I'd hate to not lift it enough and have to redo it. Also, what about the clutch and steering linkage when I lift the body? are those parts normally included in a body lift kit? Any advice is appreciated.
Read more: http://www.jeep-cj.com/forums/f19/minimum-lift-33x12-50s-6899/#ixzz152XSv765
