need to replace steering box
nanasjeep
- southern indiana
- 1984 cj7 258 I-6 transmisson was changed to automatic before we got it
It is a pretty straight forward job. Just be careful removing the pitman arm, JR74CJ5 about lost a finger removing his. -->> http://www.jeep-cj.com/forums/f98/jrs-74-cj5-build-i-go-11231/#post91978
Also see -->> http://www.jeep-cj.com/forums/f19/pittman-removal-11218/
Keep the nut threaded on the shaft so the arm does not fly off. Don't forget the pitman should only go on one way, one grove in the splines is larger than the others.
Also might want to look at changing the steering box coupler if it is even slightly worn while you are at it. It's number '3' on this page -->> Jeep CJ Steering Parts or you may be able to rebuild it (I always just replace them as I'm to lazy to rebuild them).
Here is a discussion on a replacement Cardone steering box. -->> http://www.jeep-cj.com/forums/f19/cardone-steering-box-oreilly-11435/
