New ball joint help
steve801
After tightening the lower ball joint jamnut to 75 pounds I proceeded to tighten the upper split ring to 50. With that I was surprised to see how far down the split ring goes on the upper ball joint stud. I can definitely see the split ring threads now as it contacts the rubber ball joint cover and I am not at even at 50 pounds of torque yet. Does this sound right? How much of that split ring should be seen below the yoke? I assumed I wasn’t going to see any at all. (Moog Ball Joint Kits: K8194T & K8195T)
