    To dismiss this notice
    click the top right X.
New Dana 44 Locker
New Dana 44 Locker
Im Not Spam
News Posting Bot
In Cyber Space.
The Information Highway.
New Dana 44 Locker
Locked up with a flip of the switch.
AUBURN GEAR INC.
AUBURN, INDIANA
PRESS RELEASE
Auburn Gear Inc. introduces the Dana Super 44 ECTED MAX selectable locking with 35 teeth axle shaft splines in a 4-pinion design. Part number 545021 will fit 2007 to present Jeep JK Rubicon, all ratios. The case trunnions are larger to accommodate the 35-spline axle shaft; this unit requires new differential bearings part number (JLM704649 cone & JLM704610 cup)
An upgrade in axle shaft is required, Auburn suggest upgrading to chrom-moly aftermarket axle shafts.
This new performance differential is selectable via a dash or console mounted switch. When selected “off” the differential performs like a Limited slip differential for street performance. When selected “on” the electrical differential becomes a full locked differential or spool for off road use. Auburn Lockers are also available
for Dana model 30, 35 & 44, Ford 8.8”, GM 10 & 12 bolt, AMC20
New Dana 44 Locker | Digg It | Add to del.icio.us
More...
