New driveshaft decision
I have recently replaced the T-150 in my 78 CJ7 with a T-18 , which has a 4" lift and will now need a rear driveshaft that will be shorter. I am dropping the Transfer Case down with shims between the skid and frame as it would have been from the factory. With the standard stock driveshaft I had no issues before the swap with u-joints or vibrations. Since my angle is going to be a bit steeper maybe I should consider a double cardan style driveshaft? Here is a little drawing I made with my specs, I would appreciate any thoughts from guys who understand the math. I know it would be easy to just spend double the money and go with the double cardan driveshaft but just wonder if its really necessary. The drawings measurements are right on and I just wondered based on my numbers if it was obvious that I should lean one way or the other.
Thank you
Thank you
