New Extended REAR Shock Mounts?
rocmoc
- 1970 CJ5, V6, 3spd, power steering, headers, electric fans, upgraded larger radiator, '78 grill, disc brakes (front only), swing pedals, hyd clutch, extended front shock mounts, upgraded front driveline w larger u-joints, warn OD, D30 front diff, lockers, 2100 carb, working on a '74 tub replacement, '78 windshield frame with '78+ Acme hardtop
I have searched everywhere and found nothing. I WANT to extend the shock travel in the REAR but have found no examples. Front is easy but what do you do in the rear? Pics and photos greatly needed. I assume you have to cut the tub to make room for the extended mount on the top. Help, info please! Jeep is a '70 CJ5 . OR is it even worth the work?
Thanks,
rocmoc n AZ/Mexico
Thanks,
rocmoc n AZ/Mexico
