new springs equalled lift
thistle3585
- IN
- 1979 Jeep CJ5 with '72 304 V8, MC2100carb,T150 trans, AMC20 rear diff with locker, Dana 30 front diff, Dana 20 Tr Case, Procomp Springs, Gabriel Ultra shocks.
I just replaced what I believe to be the stock springs with new, used ProComp springs on my CJ5 . Although I did not take any measurements prior to the swap, it appears that I gained about 1.5" to 2" in lift from the new springs. I'd say 1/2" of that came from the new shackles. So, I'm now looking at the drive shaft and thinking, "Is that too steep of an angle? How did that look before I put the springs on?" Hence, the lesson that you should take a measurement prior to such a job. So, my question is how much is too much of an angle on the drive shaft? How much play should be in the shaft to account for that 2" of lift? I have heard pro's and con's on using shims. Any ideas on a Jeep that will just be used for road driving? I haven't replaced the front springs yet, but will be doing that in the next week or two, so I don't want to do the job then come back and have to disassemble them and put shims in.
Also, there were no shims or spacers of any sort in the original setup.
