new to jeeps (almost)
turbodog
i went to go look at a 1979 CJ7 today (I6, 4spd). it looks very nice in pictures but once i was able to get under it, it was a whole other story. the exterior looked nice (newer paint and Golden Eagle decals) but...
first, a lot of repair work has been done to the body and frame. the frame work looks good and nicely painted (i don't think the paint is hiding anything). looks like bad was cut out and new welded in.
second, it looks like a lot of the original floorpan had been removed and some kind of fiberglass or tin tub/pan bolted/screwed on top of it. am i guessing right about being able to bolt/screw onto whats left of the old floorpan? the work done looks fine/passable and was painted nicely top (interior) and bottom (undercarriage).
now to the motor, the jeep runs strong, shifts and 4wd works. but it leaks from the engine, Transmission (that may be just the drain plug) and the Transfer Case . it wasn't dripping on the ground where the owner drove it so i could test drive (hour+). but there was fluid i could easily wipe off and it was new. the oil could be from the valve cover but how much should i worry about the Transfer Case ?
the only other problem was the gas gauge, is the factory one fixable? even the aftermarket one the previous owner tried to install doesn't work.
last is this rig worth 6500? i know nothing about jeeps. it does have a yj family rollbar installed. 83k on the odo. comes w/ soft top and softside doors (condition of both unknown).
thanks for anyone's time
