No Brake Pressure
jd8001
Hello All!
Excited to be here and working on this jeep. I'm new to jeeps and the forums.
Bottom line up front: I have replaced everything in the brake system yet cannot get any pressure on the brake pedal.
I've been following the threads but haven't posted until now. I have a 1983 Jeep CJ7 that is all stock except for a flowmaster muffler. I've been working on the brakes for a while. When I bought it it had a significant leak in the rear line right past the proportioning valve. It also had some extensive rust throughout the entire hydraulic brake system so I wound up replacing all the lines, the proportioning valve, the front calipers, and the wheel cylinders. I have also replaced the Master cylinder. I did this in two steps: Master cylinder and front calipers were step one, step two was wheel cylinders, prop valve, and all new hard lines. Upon completion of step one I still had a mushy brake pedal but I assumed that was due to the leak. Now I have no brake pressure. I have run about 2 quarts through the system checking for leaks then bleeding. I have no leaks along the lines. I can't pump the pedal and get pressure.
Ok so mistakes I know I have made. First I did not bench bleed the MC. At this point I have bled the system so much that I assume any air that was in it is now gone. Also, I have not messed with the proportinging valve stem during the bleeds. I read somewhere that if you bleed front, back, front you can omit the step with the proportioning valve. That is what I have done.
When I bleed the system I get reasonable fluid flow/pressure on the back brakes and very minimal on the fronts.
At this point I'm thinking I damaged the master cylinder or I got a bad one. My amateur mechanic skills tell me that since I can't pump the brakes and get pressure that the problem is not air in the lines but something else.
Any advice from the truly jeep savvy?
