NP231 Slip Yoke Eliinator (SYE) Install
GreyfoxVt
GreyfoxVt submitted a new resource:
NP231 Slip Yoke Eliinator (SYE) Install - NP231 Slip Yoke Eliinator (SYE) Install
Read more about this resource...
Blowing a rear driveshaft on a stock Jeep is fairly common and can ruin your wheeling weekend. The slip-yoke design on most NP231 transfer cases means that once you remove the driveshaft slip yoke out of the case and try to drive away, all the fluid will come pouring out the seal. In addition, acute rear driveline angles are a limiting factor when lifting short-wheelbase Jeeps. For example, YJ Wranglers' stock rear driveshaft’s are only about 13.5 inches long, so driveline angles increase...
