Oil change volume, vacuum and valve cover leaks
hollasboy
I just changed the oil in my '79 CJ5 (AMC 258 i6 / 4.2l I6) for the first time since I bought it. The TSM said to use 5 qts of oil if you don't change the filter, and 6 quarts if you do.
Well before I changed it, the dipstick was showing full and I only pulled about 3-4 qts out of the drain. So I added 5 qts, AND swapped the filter, the dipstick already showed over full. I ran the engine, let it sit, and rechecked and it showed more than full, so I did not add another quart like the TSM said I should.
One week later, I started to mess with my vacuum tubes which were mostly all severed and left dangling by the PO. The only change I made was to put back a line between the valve cover vacuum port (at the back of the cover, on the firewall side) to the carb air filter port - both ports were open to atmosphere before. I was told on this forum that I was ingesting dirty air into the cover and that it needed to be filtered - since there were already ports on both, it was an easy task to put a tube in there.
Around that time, I started to notice oil dripping under the engine. Oil was everywhere down there, but I could not find a specific source of a leak. I did notice some oil was dripping onto spinning parts and thus slinging it everywhere - that and the engine fan did a real number on spreading it all around. The dipstick still showed above full.
After a few more weeks, even more oil is showing up under the Jeep, especially after driving it around and parking it. I then noticed it was coming from the entire perimeter of the valve cover - leaking from everywhere. I checked the valve cover bolts, and every one of them was loose. I had lost quite a bit of oil by then, maybe a quart, and now the dipstick shows the level exactly at the full mark.
1. What is the correct quantity of oil to do in an oil change? Did I mess that up?
2. Did I overfill the oil and damage the valve cover gasket?
3. Did installing the tube from the vacuum intake to the air filter cause a problem or contribute to this?
